TOUT D'ABORD BONJOUR A TOUS
CLIO 1,9DIESEL ANNEE 94/95
J'AI UN GROS PROBLEME AVEC MON MOTEUR, IL FAUT DIRE QUE C'EST DE MA FAUTE, LORS DE MON CONTROLE TECHNIQUE ON M'A INFORME QUE MON NIVEAU D'HUILE ETAIT TRES FAIBLE, ALORS MOI GROS "BETA" NON MECANO JE LE PRECISE, CE QUE J'AI FAIT AU LIEU DE FAIRE UN SIMPLE RAJOUT J'AI AJOUTE CINQ LITRE D'HUILE, LE RESULTAT NE S'EST PAS FAIT ATTENDRE, AU BOUT DE CINQ KILOMETRES J'AI PUT OBSERVER UNE GROSSE FUMEE NOIRE QUI SE DEGAGAIT DU POT D'ECHAPEMENT PUIS LE MOTEUR C'EST MIS A S'EMBALLER, MEME EN COUPANT LE CONTACT CELUI-CI CONTINUAIT A TOURNER TANDIS QU'UNE ODEUR DE CAOUCHOUX BRULE SE DEGAGEAIT. J'AI DONC FAIT TRACTER MA VOITURE CHEZ LE GARAGISTE, QUI A CHANGE LES BOUGIES DE PRECHAUFFAGE, A EFFECTUE UNE VIDANGE MOTEUR, ET M'A AFFIRME QUE TOUT ETAIT REVENU A LA NORMALE, QUE NENNI, PUISQUE QUELQUES SECONDES APRES AVOIR DEMARRE LE MOTEUR ET AVOIR FAIT QUELQUES METRES, LES MEMES SYMPTOMES SONT REAPPARUS, L'EMBRAYAGE SEMBLE EGALEMENT NE PLUS VOULOIR REPONDRE, QUELQUES UNS D'ENTRE VOUS DOIVENT CERTAINEMENT POUVOIR M'APPORTER DES SOLUTIONS A CE PROBLEME, MERCI D'AVANCE.
